I've had a problem with straight lines since I had the TV. I'm watching a baseball game and the first base line curves just past the bag on the sides of the screen. I'm not talking about something you have to really look for but a very noticeble curve.
So I got the Video Essentials disc and got into the service menu. Colors and sharpness and everything else is now excellent, but I can't get straight lines over the entire screen. If I get the top straight the bottom is curved, and if the top and bottom are straight the middle bulges out. I've tried adjusting parabola, trapezoid etc very slowly, one at a time and I'm getting nowhere. Well, that's not quite true, there is an improvement but it is far from perfect.
Does anyone have any tips? What should I adjust first? Parabola or what? Which patterns should I use on the disc?
As far as the other settings I have now, it is set for 5% overscan. The disc says top monitors can go down to as little as 2.5 so I thought that 5% would be OK for this one. Is it or do you think I can go lower?
