Good news is I just purchased a Samsung TXN3071 for $699.00 from Sears!
Bad News is that it was a customer return and the geometry settings are so bad I can only see a small portion of the stations logo in the right hand corner among other minor issues..
Can someone give me their settings in the deflection menu so I can have a starting point to make adjustments? I think mine are so far off that it would take me hours just to acquire the correct picture..
I made it a little easier by including the adjustments so all you have to do is add the numbers.. Thanks in advance..
V AMP
V Shift
H EW
H Shift
V Linearity
Upper Linearity
V SC
H Parabola
Upper Corner
Lower Corner
H Trapezium
Bow
Angle
V Position
CXA Left BLK
CXA Right BLK
http://home.nycap.rr.com/pdquickk/Deflection.jpg
V AMP
V Shift
H EW
H Shift
V Linearity
Upper Linearity
V SC
H Parabola
Upper Corner
Lower Corner
H Trapezium
Bow
Angle
V Position
CXA Left BLK
CXA Right BLK
