1 - 2 of 2 Posts
I'm struggling to decide which TV I should go for. One is 46" 3D and the 40" is a Smart TV. The 46" is cheaper than the 40" by about $150 (including tax). I dont really care for the 3D or Smart feature. I guess it comes down to the Hybrid LED vs LED, input lag (75ms vs 62.5ms) and the number of ports available (40" has 2 extra HDMI and USB ports). This will be my first HDTV I purchase so any recommendation/advice is highly appreciated.
Since you said you don't care about the smart features I would go for the 46 inch. I went with a 40 inch 6300 and it didn't take me long to decide I wanted something bigger so exchanged it for the 46 6300.
1 - 2 of 2 Posts
