Originally Posted by shamster /forum/post/0
Any help please? I've tried searching here to compare the two models directly, but cannot find anything.
I'm by no means an expert, but figured I'd chime in since no one else has yet. I purchased the KDL-46V2500 the weekend after Thanksgiving and have really enjoyed it to this point. It's my first HDTV, and like you, I tried to research it as best I can. Honestly, I think you can beat yourself up over it if you aren't careful!! I was looking at the Sony, Samsung, and Sharp models, and even though I've read issues about all of them, I honesltly thought they all had great pictures!! I believe the Sony is using a Samsung panel anyway. At the time I purchased, I got a better deal on the Sony, but now kind of wished I'd waited for the Samsung -- I've now seen it priced the same as what I paid. My reason isn't even for picture quality -- I like the shiny black cabinet on the Samsung better than the flat black of the Sony. Also, I put mine into a stand that just fits the 46" -- it's so tight that I can't fit my hand over the top of the Sony to operate the buttons. The Samsung buttons are on the side, and I could have used them. Also, the power button on the Samsung is right on the front -- would be kind of handy when you're running out the door and can't find the remote! (at least my kids aren't fingerprinting the buttons all up since we can't used them - maybe it is a benefit!!)
You know, I think whatever you get you'll be happy with, but if you're like me you'll always second guess yourself!! I watched football this morning on a friend's new 50" Samsung Plasma and started wondering if I should have went with plasma instead of LCD!!
You mentioned the other Samsung - 4696. I think the only difference on that is that the 4696 accepts cable cards while the 4695 or the Sony do not. If you plan on using a cable box, then it would be a waste of money. The cabinet may be a little different also - glass bezel on the bottome and a round stand instead of square.
Scott
