12361 - 12380 of 18881 Posts
I'm deep enough into G section that there aren't many heavy trees directly to my south, just a lot of (mostly) single story homes. I'll definitely look into antennas which are both UHF and VHF capable. I usually watch channel 7 news, so it's a bummer to hear that it's spotty. Thanks for the advice!
Here's your TV Fool report for your street intersection:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=f1f0f9f9e2a445
There's a large area around this intersection where the predicted signal strengths are equal.
Signals are mostly weak but not impossible. Mine are weaker. It will require a preamp and a good outdoor antenna that's high enough to clear the trees. You'll need a notch filter for KRCB on channel 23 because it'll overload any preamp.
I wouldn't consider any antenna smaller than the Winegard HD7698P or the AntennaCraft HBU55. A good preamp would be the Clearstream Juice.
Cost:
HD7698P - $125
Preamp - $80
Notch Filter - $125
Coax, Mast, Mounting, etc - ???
Since all the San Francisco stations are 2 edge, I can almost guarantee you that you'll receive all the stations but not 100%. There'll be conditions where the stations won't come in. There's no way to know without trying it.
Chuck
Interesting comment about your neighbor's trees. So did the conversation go something like, "Good morning Earl. Hey listen, those two trees of yours are really cocking up my TV reception. Can I pay to have them trimmed for you?" If so, at what point do buying fancy antennas, mounts, trimming neighbors trees etc outweigh the cost of just staying with cable and having tons more programming to watch? Hmmm
Actually, I didn't know what the issue was at the time. My neighbor just trimmed his trees because he wanted to. After he was done, I saw a marked improvement in reception. With a VHF antenna channel 7 and 11 will not be spotty at all. There is a police officer in the G section who has a humungous antenna on his house, really really tall mast. I recall him saying that his reception was excellent. That was a number of years ago. I'm not sure that you would need all that humungous an antenna, just a good one. I don't know that you need as much height as he has either. I've got a 10' mast, or so, attached to the chimney of my single story home and it works just fine, except for the VHF stuff that is my own fault because I don't have a VHF rated antenna.
Is this current or a long time ago? I know a retired CHP officer and ham operator who lived in the Santa Rosa area with a ham tower and high TV antennas but this was back in the early 80's. He said his TV reception was fine. A "humungous" antenna is probably a ham antenna and not a TV antenna.
Chuck
Ktvj
Has anyone noticed a reception issue with KTVJ today? I've attached the image from yesterday showing the nominal (yellow) and enhanced (magenta) signals for KFTY and KTVJ. I added two traces from today, blue trace 11:40 am and green trace 2 pm. KFTY appears to be a little above nominal but KTVJ by 2 pm is about 12 dB weaker at the low end and 20 dB weaker in the middle. This is not right and I don't think it's just conditions. The KTVJ power slope is much steeper than yesterday. I'll keep an eye on it just in case I'm getting fooled.
Edit: I guess it was just conditions as the signal has recovered its shape and much of its strength but still below the last 3 days. The path to Mt. Tam must be much different than the path to Mt. St. Helena.
Chuck
Not "bad", but a substantial difference in audio quality from 11.1. They both have a lack of lower mid-range, lack of depth, lack of richness. . . . like someone put a thick blanket over the speaker output.
Might just "business as usual" with a lot of compression
and whatnot, because "Dancing With The Stars" audio
last night was OK, understandable, but not great, which
may be what you're noting...could be "crisper", right?
I'm always shocked at all broadcast audio after watching
one of my Blu-Rays with the DTS Master Audio, set so
normal conversation in the movie is like normal
conversation in the room. Then when the motorcycles
or other loud vehicles start rumbling in the movie, the
dinosaurs start stomping around, whatever, it is LOUD,
and beyond that, it hits you in the chest, and rattles the
windows and moves the floor, even more so than the
most current laughable "theater experiences".
Then going back to broadcast audio, running through
the same sound system, it sounds all muffled and soft.
I'm not sure if the FCC still has the dynamic range rules
they used to have, sometimes you get a little boom out
of broadcast, but nothing like a Blu-Ray.
maxreactance
Chuck
Definitely not the same person. This was in the last 5 or 6 years. The antenna wasn't really all that humungous, just a super-super fringe variety. I know what a ham rig looks like. I saw some web stuff about it and went to see the system. Definitely TV and very tall, complete with a lot of guying. Very unusual look for this area....
Chuck
Earlier today around 10 am and later about 1 pm, KTVJ was at it's normal level of 19 dB SNR, 76% on the HDHR receiver. When I just read your post I checked on it and the signal was doing the same thing as it was the other night, varying a lot from 76 to about 70 with occasional dips to 65, 19 dB down to 16 dB, but now it's settled back in at a steady 76, 19 dB, and isn't changing at all. Signal quality on the HDHR holds at about 68%.
Conditions or transmitter problems??? I don't know. I'm receiving the station off the side of my 10 element High VHF yagi pointed toward Walnut Grove. I don't have anything for low VHF except the LP345 and that's locked in at 220 degrees. I get KTVJ at 13 dB SNR off the back of it.
Larry
Larry
I'm also seeing it back to normal. I wasn't able to check it the other night when you were having problems. Conditions didn't seem to be unusual this afternoon on any other stations. I'll say something here if I see it go down again when nothing else is.
Chuck
OK... I'll spot check it this evening to see what the signal is doing. We have solid overcast here due to low clouds and fog. I haven't seen the sun all day here.
Right now KTVJ is varying between 70 and 80% on the HDHR and 17 to 20 dB SNR, no errors, on my Sony, where it was steady at 76%, 19 dB earlier.
All of the other signals have been about normal today... nothing exceptional noted.
Larry
Chuck
Bedroom wall outlet ... spectrum analyzer readings. Today @ 8 pm
4- KTVJ ...... 57.5 dbuV, 23 SNR, 21 MER
3- K03HY...... 30.0 dbuV
2- KFTY ..... 34.4 dbuV
- Turning on that "known problem" electronic ballast (created a signal / noise ? )
3- K03HY 31.7 dbuV (rapid like pulse)
Larry
Spectrum analyzer test on those coax "FM Traps" made for tv. Usually sold at Radio Shack.
Test from the bedroom wall coax tv outlet. Test 88.5 FM
Before trap installed .....83.4 dbuV
After trap installed .......74.2 dbuV
Doesn't seem to trap very well. :eek: More like a "FM dimmer" :rolleyes:
Verdict ... do not buy.
Not for TV reception, but I had a neighbor's tree removed at my expense, because it was making a mess on our driveway; when we asked them about it, they said they had been trying to kill it for years, but when they went on a long vacation it got too established; they were happy for it to be gone at no cost to them. The tree in the way for me is an oak tree about the same age as the house, we just put the antenna way in the back of the property, on a detached garage so it has LOS without oak leaves.
Chuck... Every time I've spot checked KTVJ tonight the signal strength has been between 70 and 76, 17 - 19 dB. I didn't notice any big swings.
Larry
Larry
I haven't seen anything unusual since when I posted. Looks okay this morning. Must have been conditions but it was one of the strangest fades I have ever seen with KFTY completely unaffected. Looks normal this morning.
Chuck
Cost:
HD7698P - $125
Preamp - $80
Notch Filter - $125
Chuck
Hey, thanks Chuck.
That's a lot of great info, and a bit less costly than I thought. I'll certainly look into it.
Regarding the cop in G section...there is a cop who lives down my same street. I ought to walk over there and see if he's the one with the antenna on his house. If so, I'll ask him about it.
Thanks again everybody!
As of 2 pm, KTVJ's signal is higher than it has been. It's up to 87%-71% signal quality and 21 dB SNR this afternoon, and holding very steady.
All of the other signals appear to be at about normal levels.
Larry
KTVJ has not recovered to what I saw on Saturday-Monday but much better than yesterday. KFTY has been typical. It could be that KTVJ is not as strong as I was expecting and the weekend was just exceptionally good. Every time there's lightning over the Sierras I get errors on KFTY and KTVJ.
Chuck
