19281 - 19300 of 19414 Posts
Once the signal hits a mountain it stops, adding power or rotating the antenna wouldn't really change anything for areas past that. Once that happens unpredictable effects like knife edge diffraction dictate how well the signal can be recieved and not the power.
South Bay has LOS(line-of-sight) to Sutro tower:
3141030
Where in the South Bay are you and what kind of antenna are you using? There is a RF 7 LPTV station in Monterrey that could potentially affect things in portions of that area, especially when the boost conditions are good. Can you post the link to your rabbit ears report?
BTW, the directional pattern is likely to protect adjacent KSBW on RF 8. The TV study with KRON's construction permit says it causes 0.43 interference to KSBW, and the limit is 0.5.
If you're still using that FlatWave, that's the bigger issue. Contrary to what their marketing info says about supporting VHF-Hi, its 14"x14" dimensions (with internal elements that are smaller) are not optimal for VHF reception, so it performs worse the lower the RF number.
If you upgrade to that other model with an external VHF element you should have an easier time pulling in KRON, although a traditional full band Yagi style antenna would do a lot better and get you addtional channels like KRCB and KQRO-LD.
I live near Union Square area. However, I can't picked up any tv stations broadcasting from Mt. Allison or Monument Peak. Also, I can't picked up LPTV from San Bruno Mountain at all. I've only can picked up tv stations that are transmitting from Sutro Tower and full-power tv stations from San Bruno Mountain. Any suggestions to pick up other tv stations in the bay area?
How to receive KRON 4 in San Jose area despite KRON 4 efforts to the contrary (I am sure their advertisers are happy with KRON 4 signal being practically unavailable in this 1M+ market) :
1. CM-4228HD antenna EXTREMEtenna 80
2. This might be sufficient but my TiVo was showing SNR of 19dB or signal strength of 48% which shows up in yellow.(green starts at 20dB or 50%) Picture was stable but given the possible fluctuations in signal strength in bad weather I was afraid the signal can degrade.
3. As part of a bundle Channel Master sells an amplifier which may make things better. I used KT-700 pre-amp from Kitz giving me an extra 3dB (according to TiVo) and putting the signal strength in green at SNR 22dB or 55%
4. In case you have no hardware skills: Frank from Carrillo Antenna is highly recommended. Frank has been installing CM 4228 antennas for the last year and getting consistently great results with them. The performance is not a result of good luck as some are attempting to imply.
No.ChannelNameVideoAudioHD/ATSC3
11.2KAXT-SDMPEG2AC3
22.1KTVU-HDMPEG2AC3HD
32.2LATVMPEG2AC3
42.3MOVIES!MPEG2AC3
52.4BUZZRMPEG2AC3
64.1KRON-TVMPEG2AC3HD
74.2AntennaMPEG2AC3
84.3CourtTVMPEG2AC3
94.4QuestTVMPEG2AC3
104.5Shop LCMPEG2AC3
115.1KPIX-TVMPEG2AC3HD
125.2StartTVMPEG2AC3
135.3DablMPEG2AC3
145.4FAVE TVMPEG2AC3
157.1KGO-HDMPEG2AC3HD
167.2LOCLishMPEG2AC3HD
177.3ThisTVMPEG2AC3
187.4HSNMPEG2AC3
199.1KQED-HDMPEG2AC3HD
209.2KQED+HDMPEG2AC3HD
219.3WORLDMPEG2AC3
229.4KIDSMPEG2AC3
2311.1KNTV HDMPEG2AC3HD
2411.2COZI-TVMPEG2AC3
2511.3KNTV-HDMPEG2AC3HD
2611.4COZI-TVMPEG2AC3
2711.5NBCLXMPEG2AC3
2814.1KDTV-HDMPEG2AC3HD
2914.3getTVMPEG2AC3
3014.4EscapeMPEG2AC3
3115.1KQTA-LDMPEG2AC3
3215.2KQSLMPEG2AC3HD
3315.3CMC-TVMPEG2AC3
3415.4MBCMPEG2AC3
3515.5UChannlMPEG2AC3
36*15.7K-LOVE
AC3audio only
3716.1Hai LeMPEG2AC3
3816.2Hanh LeMPEG2AC3
3916.3VietSkyMPEG2AC3
4016.4VLifeMPEG2AC3
4116.5QHTVMPEG2AC3
4216.6NetVietMPEG2AC3
4316.7AWMMPEG2AC3
4416.8VBSMPEG2AC3
4516.9U-ChTVMPEG2AC3
4616.10VNA TVMPEG2AC3
4716.11SETTVMPEG2AC3
4816.12IBC-TVMPEG2AC3
4916.14VVegasMPEG2AC3
5016.15NetVMPEG2AC3
5116.16VMTVMPEG2AC3
5216.17ChidaTVMPEG2AC3
5318.1KQRM-LDMPEG2AC3
5420.1KOFY-DTMPEG2AC3HD
5520.2ChargeMPEG2AC3
5620.3PosiTiVMPEG2AC3
5720.5KOFYMPEG2AC3
5820.6Local NMPEG2AC3
5920.7KOFYMPEG2AC3
6020.8FunRoadMPEG2AC3
6122.1KRCB-DTMPEG2AC3HD
6222.2KRCB-CMPEG2AC3
6322.3NHKWorlMPEG2AC3HD
6424.1DiyaTVMPEG2AC3
6524.2JTVMPEG2AC3
6624.3AntennaMPEG2AC3
6724.4FunRdsMPEG2AC3
6824.5VietBayMPEG2AC3
6924.7NewsNetMPEG2AC3
7024.8ChangTVMPEG2AC3
7124.11QVCMPEG2AC3
7224.12QVC2MPEG2AC3
7326.1KTSFMPEG2AC3
7426.3MBCMPEG2AC3
7526.5VietdayMPEG2AC3
7626.6VSTVMPEG2AC3
7726.11KTSF-11MPEG2AC3
7828.1KCNZ-CDMPEG2AC3
7928.2HSNMPEG2AC3
8028.4SINOMPEG2AC3
8128.6ShopLCMPEG2AC3
8228.7MjestadMPEG2AC3
8330.1KMMC-LDMPEG2AC3
8430.2BluesMPEG2AC3
8530.3CMC-USAMPEG2AC3
8632.1KMTPMPEG2AC3
8736.1KICU-HDMPEG2AC3HD
8836.2KEMSMPEG2AC3
8936.3CCTVMPEG2AC3
9036.4DECADESMPEG2AC3
9136.5TheGrioMPEG2AC3
9238.1KCNSMPEG2AC3HD
93*38.2SkyLinkH264AC3H.264 SD
9438.3SBNMPEG2AC3
9538.5NTDMPEG2AC3
9638.6NTD EngMPEG2AC3
9742.1TCTMPEG2AC3HD
9842.2UChurchMPEG2AC3
9944.1KBCW-DTMPEG2AC3HD
10044.2COMETMPEG2AC3
10144.3MeTVMPEG2AC3
10244.4TBDMPEG2AC3
10344.5CIRCLEMPEG2AC3
10445.1KQRO-LDMPEG2AC3HD
10545.2CMC-USAMPEG2AC3
10645.3CMCMPEG2AC3
10745.4KQSLMPEG2AC3
10845.5BluesMPEG2AC3
10945.6DaystarMPEG2AC3
11045.7HosannaMPEG2AC3
11145.9HeartlaMPEG2AC3
11245.10AUNMPEG2AC3
11348.1KSTS-HDMPEG2AC3HD
11448.2TeleXMPEG2AC3
11548.3KSTS HDMPEG2AC3HD
11648.4TeleXMPEG2AC3
11748.5NBCLXMPEG2AC3
11850.1EstrellMPEG2AC3HD
11950.2AztecaMPEG2AC3
12050.3QVCMPEG2AC3
12150.4Shop HQMPEG2AC3
12250.5beINMPEG2AC3
12352.1KDTS-LDMPEG2AC3HD
12452.2DaystarMPEG2AC3HD
12554.1KQED+HDMPEG2AC3HD
12654.2KQED-HDMPEG2AC3HD
12754.3WORLDMPEG2AC3
12854.4KIDSMPEG2AC3
12960.1KPJKHDMPEG2AC3HD
13060.2PJKF24MPEG2AC3
13160.3PJKNHKMPEG2AC3HD
13260.4PJK604MPEG2AC3
13360.5PJKFNXMPEG2AC3
13460.6PJKJAZZMPEG2AC3
13565.1IONMPEG2AC3HD
13665.2BounceMPEG2AC3
13765.3CourtTVMPEG2AC3
13865.4GritMPEG2AC3
13965.5LaffMPEG2AC3
14065.6HSNMPEG2AC3
14166.1KFSF-HDMPEG2AC3HD
14266.2KDTV-HDMPEG2AC3HD
14366.3BounceMPEG2AC3
14466.4GritMPEG2AC3
14566.5JusticeMPEG2AC3
14666.6TwistMPEG2AC3
14768.1KTLN-HDMPEG2AC3HD
14868.2MeTVMPEG2AC3HD
14968.3MeTV SDMPEG2AC3
150*106.1KBKF1HEVCADTSATSC3 RF 6
151*106.2UChnHEVCADTSATSC3 RF 6
I am no longer using FlatWave since the amplifier was doubling the frequencies of all FM radio stations making weak signal VHF reception difficult.
That CM 4228 doesn't appear to have any dedicated VHF elements, many 3rd party sites just list it as a UHF antenna, and the detailed specs says it has about half the range for VHF-Hi compared to UHF.
For optimal VHF reception you need something with dedicated VHF dipoles (something that looks like Antennas Direct's VHF Kit) or a traditional yagi style antenna like Channel Master's Digital Advantage (CM-2xxx) series for VHF-Hi, or their Advantage (CM-3xxx) series if you want something full band that will get you the VHF-lo channels.
That CM 4228 doesn't appear to have any dedicated VHF elements, many 3rd party sites just list it as a UHF antenna, and the detailed specs says it only has half the range for VHF-Hi compared to UHF.
For optimal VHF reception you need something with external dipoles or yagi style.
The performance on VHF-Hi is adequate, VHF-Lo is a different story. There is also visual appeal which might be important to some.
Let's post a picture of CM-3020 to compare: ;)
Until they move to the mountain top, do not worry about the RF 7 in Monterey, it is SOOOO weak we can't see a hint of it in Santa Cruz! Ch8 is more likely to cause interference.
Keith
Several stations have recently changed their programming. Virtual channels 3, 4, 18, 20, 28, 32, 38 and 50 have all changed - and Skylink in Chinese is only transmitting audio on 38.2. I updated my lists today but haven't had a chance to proof read them yet. Let me know if you find any errors.
You'll find the virtual, transmitter and repack listings all listed here:
Larry
Nobody can get KRON 4 in South Bay because of a possible interference with an adjacent channel in Salinas based on a model with the below disclaimer?
Irregular Terrain Model (ITM) (Longley-Rice) (20 MHz – 20 GHz)
Disclaimer: The ITM software was developed by NTIA. NTIA does not make any warranty of any kind, express, implied or statutory, including, without limitation, the implied warranty of merchantability, fitness for a particular purpose, non-infringement and data accuracy. NTIA does not warrant or make any representations regarding the use of the software or the results thereof, including but not limited to the correctness, accuracy, reliability or usefulness of the software or the results
I think KRON 4 should commission a new study.
When I rescan the channels. I notice my tv puts KMTP 32.1 instead of 32.4 or 38.2. Also, 38.2 has changed to SkylinkTV, but I've only gotten the audio feed instead of the video feed. Has anybody has the same problem as I did?
I only got audio feed from 38.2 also on both of my DVRs (Magnavox and LG). However I can get video from 38.2 on my Insignia TV that I bought a year ago. My guess is 38.2 changed its coding format that older sets no longer can decode its video (?). The reason I noticed that was because SkylinkTV switched from 4.2 to 38.2 starting June 1. There are a couple of Taiwanese news talks I'd like to follow.
That's a very standard disclaimer. Longley-Rice is the standard propagation model used for pretty much all TV analysis.
- Trip
- Trip
Tough choice - screwing advertisers (and viewers) in a 1M+ market or verifying a theoretical study using empirical data.
