Status
Not open for further replies.
1 - 3 of 3 Posts
Hey guys:
I was watching the WB on Channel 20 DTV and both the Dolby Digital and PCM signals dropped out. Did anyone have the same problem?
Typically, Channel 20 is rock solid.
Yea I noticed it to during One Tree Hill last night on the HD broadcast. There was no audio till the last commercial break, when they switched it to a 4:3 upscale of the SD. The SD broadcast on 20-2 had sound the whole time so I had to watch that instead :(
Hopefully tonight's smallville season premiere won't have that problem.
I had the same problem, and it happen to both shows. When the shows came on the audio dropout right away. They had the same problem on last Saturaday on the repeat shows. Seems like technical problems when switch from DTV to HDTV.
1 - 3 of 3 Posts
Status
