The desire for hearing neutral and 'perfectly uncolored' cannot be fulfilled by buying a speaker with a flat frequency response, unless you are a perfect entity.
People forget the essentially subjective nature of hearing, one that is even beyond conscious thought - the unique physiology of each ear!
Everybody should get their ears checked at a hearing institute. They can test your hearing frequency capabilities and graph it, much like with a speaker (but kind of opposite). Then, you should take that chart, and seek a speaker the frequency response of which makes up for your shortcomings, and is slightly lacking in your best frequencies.
If you are a true audiophile, you will go beyond what the producer intended you to hear (after all, they mix with their non-flat ears) and hear the closest approximation of a flat sound in this way.
This also supports the argument for slightly 'scooped' eqs, because they make up for the usual tapering-off of hearing in the extreme highs and lows.
