Although I do not own your TV, I can give you my HTPC specs
and whar resolutions I use
1080i native for DVDs, videos, images, 720p underscanned to fit display for gaming
and the only resolution on directview CRT which has readable text and no flicker is 480p
so wouold be what I used if I surfed on my TV, only downside thats is 480p is 4:3 and not 16:9 and 480p has no underscan options in the drivers settings
so you got to use powerstrip
I will say this as well, directview CRTs are not PC monitor replacements
but anyways, my specs are XP MCE, 2.4 Ghz, nvidia 6800, M audio Revolution 5.1, 600 GB of HDD, 768 PC 800, Fusion HDTV 5 Lite, Hauppauge PVR 150 MCE, DVI to HDMI on my Sony KD30XS955
