1 - 1 of 1 Posts
Hello everyone. I have a big problem hopefully someone can help with.
The lamp replace light went on a few days ago and so I purchased the new bulb, but now the projector will only project an image for a little over 2 minutes and then shut down, and about 1 minute later it will display the "Ready" signal, and again only display for 2 minutes.
Now, the projector has been dropped, but was working fine regardless. I read it might have been dirty, but after opening it up to take out the bulb, spraying the entire system and ducts with Dust Removing CO2 cannisters, and noticing no excess dust, the reassembled projector still does not project longer than 2 minutes.
Thank you all for your time.
-David
1 - 1 of 1 Posts
