Hi
I’ve just purchased the Sanyo PLV-Z1 projector which I think is an outstanding projector for the money. I do have few questions that I would greatly appreciate an answer on,
1 Sanyo does not indicate a lamp life. How many hours have you put on the Z-1 before you had to replace a lamp?
2 The first day I got the unit I didn’t have a proper ventilation around the unit and the unit overheated after 3 hours in the Theater mode and shut down by itself. Is there any damage done to the unit or is this a common think on the front projectors. (it works fine today)
3 The back of the unit gets very hot . You can’t keep a finger on it without getting burned, is that normal?
4 Do all of you provide additional cooling to the unit like a fan or not?
5 I hear different stories about the warranty on the Z-1, some say it’s 3 years Sanyo website is 1 year? I had not received any warranty papers with the unit even though it was brand new unit, manufacture sealed.
6 Any known issues on this projector?
