1 - 2 of 2 Posts
I did a search but didn't see an applicable answer. How difficult is it to swap the old housing to the new lamp? Will anything associated with re-using the old housing, shorten the new bulb's life?
The one thing that could definitely shorten the life of a new bulb is if you touch it with your fingers (or get any other similar dirt on it) and do not get it totally clean again. This would be more likely to happen during the installation of a bare bulb into the housing.
1 - 2 of 2 Posts
