I know this projector is old, but please don't respond that I should trash it.
I recently got a Sanyo PLV-Z3000 and it worked for about 10 minutes. It has a great picture, but I was cycling through the presets and hit a snag. It was working great when I got it in Natural mode. I cycled down to x.v. Color and that was still working. Then I went one more (back up to Brilliant Cinema I believe) and I heard a whirring noise inside and the projector shut down after about 2-3 seconds. The power and warning lights are solid red - I see from the manual that means an abnormal condition.
The problem now is that it will only work in the menus. Any time I switch to an active video input it makes the whirring sound and shuts down with the error. I tried resetting to factory defaults and I've tried changing the preset quickly before shut down. Nothing makes a difference.
From my research, I believe it's the cinema filter mechanism because it faulted after going into a Cinema preset. I believe the cinema filter is stuck in a position not fully in the path or out of the path. The noise sounds like a geared motor spinning but not engaging any teeth to move the filter.
Has anyone seen this before? It's a long shot, but does anyone have the service manual that they could share?
I'm pretty good with electronics repair, but I prefer to do research first before I jump in. I've taken the top off and I'm at the motherboard. It still seems like there is no way I can check the cinema filter without removing it as well.
I think I've found the red and black wires going to the motor for the cinema filter drive. Second picture, top right. These are from the German Art & Voice review, but I can't post the link because of my post count.
I'm hoping even if the cinema filter gear track is dead, I can either engage it or disengage it and disconnect the motor power.
Any tips?
Any tips?
