Status
Not open for further replies.
1 - 2 of 2 Posts
Hey guys and gals, I hooked up the plv to Dish 6000 and when using the 1080i through 15 pin RGB connector the picture is very dark. It cannot be adjusted lighter!! It works fine with 720p. Any ideas? Also what is the best way to hook up HDTV? Would I be better off using input # 2 and getting a break out cable? I need to hook up progressive scan DVD, HDTV(Dish 6000)Looking for best picture for both.Any and all input greatly appreciated!!!
Scott
1 - 2 of 2 Posts
Status
