Hey all, need some input. Replaced my 4 year old sanyo plv z3 bulb, the old one busted into pieces. After replacement the lamp I try to power it on, it buzzes for a second, I see some blue from the lens then the lamp indicator flashes and no light from the lens. Zip, nada.
Called Sanyo, hit the reset button in the back, same thing.
Any other ideas?? Some say to remove the cover?? I have done that. Is there another reset button hidden inside of this unit????
Thanks for any info at all!!!
Maybe time to just send it in for service.
