1 - 2 of 2 Posts
· Registered
Hi,
I've spent the weekend building my first HTPC and pretty much all's well - it's even nice and quiet! Except..
The fan on my graphics card basically switches itself on and off every 20 seconds... I can watch the GPU temperature in CCC - it starts at 55 degrees, takes 10 seconds to get to 63 degrees. Then the fan comes on - the temperature drops to 55 degrees (10 seconds). The fan switches off. Repeat. ad (literally) nauseum.
It's driving me spare! I'd be happier if it was on all the time :-/ The card (it says v2.0 in the corner of the box - can't find any reference to this) has a big fan on it (so needs the space of two slots).
Also, I can't control the fan speed in CCC - I can move the slider but nothing happens - I'm on the latest drivers from the ATI website.
I've searched relatively thoroughly, but come up with nothing. I've seen some people talking about removing/replacing the fan - and found a link to a fanless heatsink which is (allegedly) compatible with the 4950 chipset - but I've no idea if that means if it's physically compatible with the board as well.
I've also seen some reference to the fact that Sapphire boards use non-standard fans - which might explain why I can't control it in CCC. although I'd rather not set the fan to a constant speed - I'll just end up overheating it if I play FarCry 2 or something....
Does anyone have any advice?
Many Thanks, Jeremy
· Registered
I ended up replacing my fan (on my 4850) with an upgraded cooler and fan. I can't control fan speed, but it's silent and runs MUCH cooler. Downside besides the obvious extra cost is the cooler itself is about the same size as the card.
1 - 2 of 2 Posts
