It depends on if the ram is the same. If it is it will only be useful for gaming if not then don't bother if slower.
Graphics ram in order of preference - GDDR4, GDDR3 then DDR.
Originally Posted by Tiernan /forum/post/12884784
Both listings indicate GDDR3, but there seems to be some debate, as at least one reviewer indicated that the 256 is only DDR3. It's not clear if that is also the case for the 512, but they seem to have the exact same configuration otherwise, so it's likely to be DDR3 also. As I would like to do a little gaming with it, I was assuming it would always be worth having more memory, especially if they're the same type anyway.
