Status
Not open for further replies.
1 - 1 of 1 Posts
I have an RCA DTC 100 and have installed the Sat C kit and combiner.
I do not get any signal strength on transponders 8, 19 and 12 (110). I am using a single round dish for the 101 sat. and an oval dish for 100/119. I get channels 199/509 fine in HDTV and all the other channels appear normal. I put the Sat C LNB in the center position on the oval dish and the IRD is set to oval/ 3 LNB's. Sat C LNB/combiner/multiswitch are wired correct.
When I called Direct TV they told me 543 was activated and it does show in my program menu.
To try to isolate the problem (mine or Direct TV) I would like to know if I should be getting signal strength on 110 transponders 8,10 and 12 even if Direct TV has not activated my channel 543? If so, is it possible/probable that the oval dish is offset so it's not getting the 110 sat, I did adjust this dish for maximum signal on the 119 sat. when I originally installed it.
Sorry for the long post but I'm baffled.
Thank you.
1 - 1 of 1 Posts
Status
