Status
Not open for further replies.
1 - 3 of 3 Posts
I set up my new HD200 last night and have it connected to a Mits WT-46805 through the RGB HDTV connector. I'm using a DB15 to 5 RCA cable and have the H&V sync plugged in with the Red, Green, and Blue. The picture in 1080i mode seems zoomed with the left and right edges of material lost. The manual doesn't say anything about using the H&V sync or not, does anyone know if the Sony outputs "sync on green" or does it need the H&V sync lines plugged in?
I have'nt tried using the component HDTV connection yet because my TV isn't allowing me to choose component as the DTV input at the moment (some crazy problem I've yet to figure out).
Thanks, Any help would be appreciated.
Discussion Starter · #3 ·
Thanks JFerg.
I guess I'll try to figure out what the problem is with my component input on my TV and hook it up that way. Hopefully, there won't be the same issue.
1 - 3 of 3 Posts
Status
