Status
Not open for further replies.
1 - 5 of 5 Posts
Premium Member
One-for-all/radio shack remotes with the help of advanced codes will control your W60. Advanced codes are 3-digit codes for individual functions(PIP-034. PLAY-208). Using the Sony satellite code SAT0639. Here are some codes for the missing UTV functions;
PIP-034, PIP SWAP-114. PLAY-208, PAUSE-206, REWIND-204, FF-211, STOP-236, RECORD-207.
And all the sony remotes like he AV-3000, VL-900, VL-700, will only control the SAT functions of your UTV,and you not having the oem remote, you can't teach them the missing functions.
Discussion Starter · #4 ·
How does that remote work? once you enter those codes are the pip play record buttons on the lcd screen or do you enter the numbers to make that feature happen.
Premium Member
Different OFA remotes have different methods of entering Advanced codes(AC). For an example I'll pick Radio Shack's 15-2116 remote. You would first find a working device code, here being SAT0639.
Now you would need to plan out where the AC 's should go. Commands like PLAY(208) you would put on the PLAY button, STOP(236) on the STOP button and so on. On this remote(2116) there are PIP and PIP swap buttons. There may be some you need to put on keys that are misidentified. The only problem about the use of Advanced codes, once your finished entering a AC, you need to start over again for the next command. It can take awhile. To input Advanced codes in the 2116;
1. hold P(setup)
2. go to keymover,press select
3. screen says"from mode",select a mode(device)
4. screen says"from key",hit P(screen changes to SYNT)
5. key in ADVANCED CODE, hit select
6. screen says"to mode", select a mode
7. screen says"to key", select a key
8. screen says"success", exit setup.
1 - 5 of 5 Posts
Status
