Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
Looking for a 34" widescreen direct view set... under 3500 is the budget.
JVC's AV34WP84 seems nice but converts everything to 1500i,
what are the pros and cons of this feature?
It will be used with a Samsung DVI DVD player, Direct TV HDTV Service, and local ABC HD OTA through the Toshiba DST3100 (if it ever ships).
Any other suggestions as to a better set to fit this criteria is greatly apprecitated.
Space to fit TV is limited to 41" width.
1 - 1 of 1 Posts
Status
