The Scheimpflug adjustment on the HD700 is **incredibly** lame. I suggest that before messing with it, you verify your mechanical setup is 100% perfect. If the projector isn't perfectly square/perpendicular to the screen, you'll have problems with left-to-right focus.
Are
all three colors out of focus on the right side? If so, that definitely indicates a problem with your mech setup. Try tweaking the projector's angle to improve it.
If only one color has this problem, and the other two are OK, then you need to adjust the Scheimpflug on that color. Here's an incredibly bad picture to try to illustrate how it works.
The HD700 has 4 bolts that come out from a rear mounting plate. The lenses slide onto these bolts. There are 4 "rear" nuts (red in the picture) that hold the lenses at a particular distance. You slide the lenses onto the bolts (BE CAREFUL that you don't scratch the back of the lenses with the ends of the bolts!!!), then you hold the lenses in place with another set of 4 "front" nuts (green).
To adjust the Scheimpflug angle, you twiddle the rear (red) nuts to change the angle of the lenses. So e.g. in your situation you would move the two rear nuts (on one side or the other) back a turn or two, and tighten up the front nuts. So e.g. if you moved the two rear bolts on the LEFT side of the lens, that would turn the lens slightly towards the left.
It's a pretty cheezy design, and it's a PITA to get your fingers back in there, but it does work.
Gary
