1 - 4 of 4 Posts
Discussion Starter #1
I have the SA 4250HD with Charter Cable. I am running into a pioneer Elite VSX - 94TXH and an infocus lp640 via an HDMI adapter.
I can't seem to get a good handshake with the infocus plugged in. With out it...the sound comes through fine...with it...the sound keeps dropping and switching between surround and stereo.
I tried changing the cable from the box to the receiver...no luck.
BUT when I use my PS3...no problem.
What is going on?
Can you go from the 4250HD directly to the Infocus and use optical for sound temporarily? Some cable STB's have problems with the HDMI repeaters built into AV receivers.
Yup. I have a 4250HD and it works fine over HDMI with one pre/pro I have but will not do audio with the other, forcing me to use coax/opt for the sound. Same display in both cases.
Discussion Starter #4
interestingly...it seems to be an issue of WHEN things are turned on as well...when I switched back to the TV from the PS3...the synch stayed pretty solid. WEIRD!
1 - 4 of 4 Posts
