1 - 4 of 4 Posts
I have a pair of Altec Lansing model 6-II's that I'm using as mains currently. There is a noticeable scratching noise coming from 1 of the midrange speakers. Most of the time it isn't really noticeable but specific songs or parts in movies get really annoying with this. I noticed today that adjusting the l-pad also creates a lot of this scratching noise, so it that a problem with the crossover or do I need a new speaker?
It sounds like the l-pad pot is corroding.
You should be able to fix it with some electrical contact cleaner.
If it is really bad off a replacement will be needed.
You may have two problems, but you definitely identified one.
You can try spraying some Caig DeOxit into the L-Pad to clean, de-oxydize and lubricate the contacts inside it.
If that doesn't work, you may need to replace the L-Pad.
Once you get the L-Pad problem resolved, that may very well be your only problem.
Hope this helps.
Soho beat me to it. That guy's fast.
Discussion Starter · #4 ·
Thanks for the help guys, I will give that a try. These speakers were sitting in a garage for a while and the surrounds were beyond rotted out so they may not have been taken care of, but for the $20 I payed for them I am very pleased.
It's really not a big problem, for instance right now I am listening to Whiskey in the jar by Metallica and I can't hear anything wrong with them, but music like The six parts seven really make it apparent.
1 - 4 of 4 Posts
