I am about to get my very first front PJ. It is either gonna be a Sony HS10, or, I am gonna wait for a few months and get an HS20.
The room I will be using it in has pretty good ambient light control. It can be totally dark after sunset, and have no direct light during the day. Using floor to ceiling oriental room dividers, I can make it pretty darn dark during the day as well.
Usage will be for DVD movies, HDTV watching(especially sports), PS2 gameplay, Computer use including games, and occasional SD/EDTV sports viewing.
I will be using an HTPC as my source unit for all but PS2 gaming.
Although I'd like to have a screen size which is 100-120" in diagonal size, the best place for my screen is in a room nook which is only 84" wide. That limits me to a screen which is probably 80" wide at best, and 92" diagonally for a 16:9 image.
Ideally, a pull down screen would work best for me and for the room which is a family playroom. However, I am wondering if the screen would be flat enough and wrinkle free for movie viewing?
If I go with an 80" wide pull down screen, would I pull it all the way down or only to about 45" down for watching HDTV and 16:9 movies? Is it best to have a screen which is exactly the right size for the video aspect ratio you are watching?
Finally, price IS an issue with this purchase.
I found this pull down screen on Ebay, and wonder if it would work well for my situation?
Draper Luma
Thanks for any and all help you can this FP rookie...
Draper Luma
