Status
Not open for further replies.
1 - 5 of 5 Posts
Does a line doubler such as the Iscan V2 help reduce or eliminate the screen door (combined with AE100)?
screen door has nothing to do with the source or scaler being fed, it is created by the dark areas between pixels. The only things that help to reduce or eliminate is to sit farther back, reduce screen size, or get a new higher rez projector.
Or get a CRT projector! :D
I'm sorry, I had to mention it.
Premium Member
hmm...if I had said "reduce brightness" instead of "reduce contrast" (which is really what I meant, but it's the contrast adjustment), I would have had that covered. ;)
Alex
1 - 5 of 5 Posts
Status
