1 - 2 of 2 Posts
Hey guys, I am curious, how many feet can you be away from a 100" screen before you start to see SDE for a 1080p projector?
Depends partly on the projector. LCOS projectors have almost invisible structure. The Panasonic has smooth screen which eliminates. I would think that you would want to sit farther back from the screen for eye comfort than would see SDE.
1 - 2 of 2 Posts
