Status
Not open for further replies.
1 - 4 of 4 Posts
All digital projectors have screen door effect, if you get close enough. LCD are the worst offenders. It varies from model to model and higher resolution lessens the screen door effect. The rule of thumb is to be atleast 1.5x times your screen width for an LCD projector so screen door is not noticable. With a DLP, you can usually get about twice as close before it is noticalbe.
Discussion Starter · #4 ·
Thanks guys.
I should have enough funds for a projector towards the end of the year, hopefully by then there will be some HD2 chip models announced.
If I was buying right now I would be very tempted to go for a Seleco HT300.
Saf
1 - 4 of 4 Posts
Status
