I have an Optima HD131xe projector and have been just projecting onto the wall, but I think it is time for a screen. This screen will be in the main room of my apartment so it will have ambient light. It will be partially covering a window with vertical blinds so it needs to be mounted away from the wall. It can be mounted either directly to the wall or can be mounted to my bookshelf which is 59" long (I don't care if the screen is wider). It is 12' wall to wall so it will probably be 10'-11' throw. My speakers will not be behind the screen so that is not an issue. Also as far as mounting the projector, I was just going to put up a bookshelf on the wall behind the couch but read that it needed to be mounted upside down to maintain image quality? I don't want to spend a ton on a mount if I don't have to. Thank you so much for your help and if I left anything out just let me know.
