Status
Not open for further replies.
1 - 1 of 1 Posts
Hi folks,
I'm just about to start a reno on my first house that I am buying! Yippee! Started design work on the home theater... of course. Need advice as I'm a real newbie at this:
Decided on a pulldown screen that will be ceiling recessed. Plan to mount it onto a 2x8 joist. Plan is for a 16:9 diagonal at 100" or so. Acutal screen type not chose.
QUESTION:
Should I buy a mounting box/bracket now during the construction phase? If so, what should I use? I'm looking at draper and dalite. Any suggestions as to whether to get a particular mounting box/bracket and whether they are interchangeable between manufacturers. Or, should I just leave a 6" wide gutter in the ceiling and do it after. THANKS!
Wooe:)
1 - 1 of 1 Posts
Status
