Based on the formula for ideal screen position, I need to drop the image from my projector about 1 foot, but the front speakers interfere with that location. Attached is a temporary config of my "theater" showing screen position about 1 foot higher than ideal and my unmodified green textured wall.
As I see it, I could solve the problem in the following ways:
1. accept a higher than optimal image so the picture clears the height of the speakers (as shown in the attached photo, 12ft ceiling)
2. reduce the screen size so the width of the image fits between the speakers (current screen is 150" diagonal)
3. buy an acoustically transparent screen to place in front of the speakers (solves the need to smooth/paint the wall too)
What solution would you pick and why? I'd like to either begin shopping for a screen, or begin prepping the wall for my final configuration.
BTW- Anything that isn't a speaker is going to be placed in the "boiler" room with cables run in the wall.
