Status
Not open for further replies.
1 - 1 of 1 Posts
I plan to purchase the HS10 projector in the next few weeks and need to decide on a screen. Stewart is too expensive for my wallet. I am leaning towards Dalite (any others you recommend in the $400-800 range?) but having a tough time deciding which screen.
The room is 30 by 18. Screen is on the 18 foot side, mounted on a wall unit (fixed). Will be 106" diagonal. Wall unit is black, floor is oak, and walls/ceiling are medium gray. Projector will be mounted about 14 feet from screen. Moderate ambient light control (need to shade one more window, which I plan to do, but current shades are the honeycomb shades that do permit "some" light to come in, although this is limited). Most watching is evening anyway.
Is the Cinema Countour with Cinema Vision material the best screen from DaLite for this use? What about the Da Snap screen?
Am I wrong to conclude that the Cinema Vision material would be the best for this application?
Thanks in advance for your comments and suggestions.
1 - 1 of 1 Posts
Status
