Status
Not open for further replies.
1 - 3 of 3 Posts
Discussion Starter #1
I've looked around for awhile now, thought I had everything figured out for a screen size and all but now I have a problem when I use one of the calculators for screen size.
My room is 13 1/2W X 13 3/4l
Using a calculator or even the 2X the distance rule my screen would only be 23inch wide. Is that right? Can someone tell where I went wrong?
thanks.
you want to sit 2x screen width?
if you sit 3 feet from the back wall you can have a 5 foot wide screen.
optimally you would want a 30 degree viewing angle but maybe you should try something wider like a 6-7 foot wide screen. This of course should be weighed against the quality of your display device and source material.
Discussion Starter #3
when I use the a barco calculator using 85x49 (what I thought I would use) it tells me i have a negative ceiling distance. Not sure what that means?
1 - 3 of 3 Posts
Status
