Hi Guys,
So I finally have a space to have a dedicated HT, its not ideal but i'll take what I can get and want to make the best of it. I will be painting the walls and ceiling black for this purpose and the room will be light controlled so all viewing will be in the dark with no additional ambient light. The projector I am upgrading from a 720p optima is an Epson 5040ub, and my screen preference is 2.35:1. My max vertical screen size can be 56 with a boarder so I'm guessing around 130ish diagonal with the projector sitting about 13 feet back with a viewing distance of 9 feet. I have been looking into screens originally settling on a 135 inch Silver Ticket, but then I started reading and there are so many options each with pros/cons(paint, spandex, and many makes of screens) that now I'm a bit confused on what would be the best from a cost/benefit perspective. Based on my understanding I should be about at 1400 lumens in cinema mode at 22 foot lamberts on a 1.0 gain screen which I believe is good. I am also trying figure if I should go with an AT screen for the best audio experience.
Some additional info on equipment, I am using HTD level 2 speakers (towers in the front) for all five and 4 atmos speakers in the ceiling (not sure which ones yet); Sub MFW-15 with custom seaton amp and I'll be building a Marty cube with an 18" ultimax; receiver is tbd (currently have a Yamaha v667 several years old). Note the room will have acoustic treatments added also.
Any help is much appreciated, thanks an advance!
