Couple of questions.
Have a Stewart acoustically transparent screen that I getting ready to install.
I was wondering if anyone could throw out some advice for that actual finishing of the frame around the screen and how it sits in for the aperture mount?
I have been told to just friction fit the screen frame in with the fabric in the apeture.
Would you just use some molding on the front to hide the gaps?
Also as far as fabric material for the wall.....does it have to be acoustically transparent as well or just something that does not reflect too much light?
Any input is appreciated.
Thanks in advance.
Thanks in advance.
