Looking for input on the best way to mount the screen. Mount it to the wall, or hang it from the ceiling..
The screen is 80x45 on a 1x4 frame, built the long way (so there is 3.5" of depth to the frame).
My main concerns are vibration from the sub. I can dampen that if mounted to the brick wall, but will hanging cause any problems (doubt it will)
Pros and cons of each would be great. Thanks!
