I recently had my DVD player modded with SDI and am using it with a Holo3D card.
In certain scenes in red areas, I am getting small red horizontal sparkles that are red flickering throughout the area. If I pause the picture, they still appear and jump around. When I try the component inputs, the sparkles are not there. Using SDI, if I pause the picture, then disconnect the SDI cable, the picture is still there (from the last SDI data it received) but there are no moving sparkles.
This leads me to believe I have a problem with my SDI mod. The question is, what? Would it make sense that a wire inside is disconnected, but the SDI still works? The sparkles are only visible once in a while (or always on the same paused picture).
Thanks for any advice.
Mike
Mike
