Volume on the sub lowers gain of incoming signal, or lets it all in at "100%" so don't sweat it. I turn those all the way up and control the signal from the receiver anyway.. or in my last amp I bought there was no gain on it at all.
Placement - a single sub, for me, always goes front and center between the mains. It's impossible to locate and blends in like you won't believe. Front firing sealed is my chosen path for this. Corner loading may add a few SPL here and there but will also create problems, don't do it. If you're after better coverage add more subs. 2 = front and back, 4 = each wall away from corners.
BFD = loads and loads written about this thing, google it up. Yes it's cheaper than the bassis by far, and does more than the eD 2 band PEQ (the behringer has 12 bands or 24 in it's latest incarnation irrc.. i just bought one from a forum member, can't wait!)
