It can be challenging setting up bass to sound its best in different seating positions. You really need to decide where your going to listen to your sound system most (your primary listening position) and tune it accordingly to that position. I know aesthetically you like where your subs are located but more than likely they are not in the best location in your room. Not every location in a room will sound the same, just doesn't work that way as the room/MLP/sub(s) location will dictate that.
It is notorious to have boomy bass if listening position is against a back wall from the front sound stage,,, this is what your experiencing imo. If your not interested in REW and taking measurements then (based on your MLP) a sub crawl can help. At the very least i'd try and move your subs to the outside of your Kefs,,,, and not make you beds headboard the MLP.
