1 - 4 of 4 Posts
· Registered
one of drivers in my surround sound system died. it is an "Athena S Point-5 Satellite Bookshelf Speaker"
h t t p :// www.athenaspeakers.com/products/s-point-5-satellite-overview/
out of warranty, and the company no longer exists anyway, so i'm looking for a suitable driver replacement. no luck searching anywhere else.
it is 4", 4ohm, 100W max, 80hz - 20Khz
does anyone know where i might find a replacement, or something else with the same specs?
· Registered
You can try Parts Express for a replacement. The difficulty is that the Thiele/Small parameters of the replacement speaker should approximately match up with the T/S parameters of your existing speaker (when it worked).
1 - 4 of 4 Posts
