1 - 2 of 2 Posts
· Registered
Hi,
I'm trying to secure my RC-3ii to a shelf above my 50" plasma. I live south of LA so I need to be concerned about earthquakes. Any ideas on how to fasten this 29lb center channel to a shelf? I am planing on securing the shelf to studs or anchored screws. I have not hung the shelf yet, i have the 90 deg brackets but no actual shelf yet. any way to fasten the speaker to just the bracket?
Along the same lines, I am going to mount my 12lb RS-3ii's to the wall using either a screw into a stud or an anchored screw in drywall. If the bolt head fits in the slot, do i need to worrry about moderate quakes?
I realize when/if the big one comes about nothing is going to work, but i'm looking for something that will work until the apokalypse
thanks
· Registered
Discussion Starter · #2 ·
got to work last night with the studfinder. found what i thought were studs but the device was acting really weird. after measuring and thinking for a bit, i was like, lets do it! and then something dawned on me, turns out there is an electrical box on the other side of the wall EXACTLY where i need to drill for my shelf brackets. maybe the giant box filled with electrical equipement is what was making my stud finder go crazy.
Friendly reminder: check before you drill!
1 - 2 of 2 Posts
