The 1709 doesn't handle audio over HDMI, you'll need the 1909 for that. If you go to 6ave I believe it's not much over $400 right now which is an amazing deal for a very good receiver. The 1909 pretty much has it all....
Originally Posted by jinque /forum/post/16821968
thanks for the reply so far. how are the lower end yamahas? there's a couple that only support 5.1, and I don't particularly need 7.1.
Does carrying audio over HDMI gonna affect the quality of playing PS3 games much? It'll be 1 less cable but I don't care about that. A majority of the time will be spent with games, some will be through the computer which only has optical out, and then a good bluray once a while, not very often.
Originally Posted by jinque /forum/post/16822618
although more then I'd like to pay.. the denon 1909/789 does look like a solid receiver. for that price range is it a better pick than the Yamaha RX-V665BL?
Originally Posted by mbyrnes /forum/post/16822756
IMO the Denon is the better choice. Yamaha does poorly on the test bench (might be 35w/ 7 channels driven) where Denon is closer to the stated numbers. I really like the Audyssey Multi EQ room EQ. The only problems with Denon is 1) can be harder to setup. 2) It also doesn't have pre-outs if you wanted to add a separate amplifier later on.
Yamaha 665 does have pre-outs to add a separate amp.
