1 - 7 of 7 Posts
· Registered
For my home theater I have two 42" LCD's both connected to directv HD receivers. I am completing a MAME cabinet with a wrinkle that it would have a 32" LCD that I could use as a third TV during NFL Sundays and March Madness. I thought I was so smart and would just buy an indoor HDTV antenna for this to work. Unfortunately, I live outside of Chicago and the WBBM/CBS signal is powered by hamsters. Considering CBS is the most important channel for March Madness this creates a flaw in my master plan.
The only option I seem to have available is pay the $100 for an HD Receiver, install it myself and pay $6 a month for this receiver. To me (and especially the wife) this seems like a waste for a TV I will probably use 20 days out of the year.
I am just wondering if I am missing any other options? The computer is too weak to run internet TV through it.
· Registered
Unless you are prepared to obtain and, if necessary, install a proper antenna, you're probably SOL for CBS.
In order to suggest an appropriate antenna, you'll need to run a TVfool report and post it so we can see what signal conditions are probable.
· Registered
If you are using component from one of the receivers to one of your TVs you could get a component Y splitter( you may need a powered version) to output CBS to two TVs.
You are not likely to notice any degradatiion of signal quality using component as compared to DVI or HDMI.
· Registered
Discussion Starter · #4 ·
Thanks for the replies. One option I have been thinking about is putting an antenna in the basement well. I am just worried this won't help at all know matter how good the antenna is. Anyone have any experience with that?
· Registered
Why not mount it outside on the roof?
· Registered
Originally Posted by DeLarge /forum/post/18115137
One option I have been thinking about is putting an antenna in the basement well. I am just worried this won't help at all know matter how good the antenna is. ..
A valid concern.
A basement is the last place to consider installing an antenna. There is often little, if any signal down there, particularly pesky VHF signals, which are hard enough to receive on a main floor indoors.
Put the antenna on the roof, or if signals are strong, in the attic (unless you have a metal roof, foil insulation or stucco exterior walls.
For antenna suggestions, grab the TVFool results for your address and post the link back in this thread.
1 - 7 of 7 Posts
