open up MPC, then go to view menu, then options.
once your in the options menu, you'll see the playback menu, and then output as a sub-menu, click on output.
in that menu you will see directshow audio with a drop down menu.
by default, its always set to system default, use the drop down menu, and choose the secondary sound card, whatever brand name, model number it is.
and you should now be good to go.
- Josh
- Josh
