I am looking to buy Bluetooth headset. I like the reviews of the Momentum 2. does anyone have any comments or another advise? My budget is £400.
Thank you.
Thank you.
Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
I just bought these about a month ago, and used them on a couple of cross country flights recently.I am looking to buy Bluetooth headset. I like the reviews of the Momentum 2. does anyone have any comments or another advise? My budget is £400.
Thank you.
The good:
Very comfortable, feel light on the head. Bluetooth works very well, easy to connect, control volume, etc. The overall sound quality is very pleasant and smooth, if a bit recessed in the midrange. Solid bass, but not boomy like Beats, et al. Highs are very nice. Very easy to listen to for 4 hours or more on a flight, train, etc. They look awesome (I have the Ivory pair).
The not so good:
Noise canceling is OKAY. Not in the same league with Bose ( although the tonal quality is much better). Not sure if they are still "breaking in", but the dynamics and sound are not as good as the wired momentum 1s I had previously.
I would rate them 4 out of 5.
One of the more comfortable, full size, full range bluetooth headsets I have used. However, not quite up to par with their wired counterparts in sound quality, and not the best at noise canceling I have used. If you value good sound quality, comfort, and also very attractive looks, I would recommend based on the other options out there right now. I think the Parrot Zik are ugly, Bose to rolled off, Beats too Beats (LOL).
Hello!I just bought these about a month ago, and used them on a couple of cross country flights recently.
The good:
The not so good:
