not sure where the forward lobe is on those speakers. might work best upside down in this app. toed in possible?
Originally Posted by Greebster;3825530
The bounce can be greatly reduced if one is to use two drivers one much lower than the other, like in a 2.5way the added 0.5 helper woofer is used. Space this at 1/4 wavelength at the crossover frequency. Done. Loading bass into a room from the mid height is not a bad thing. If the helper woofer is placed above, within 1/3 distance of the wall to ceiling adds better correction for room modes per Geddes.
Best to sim first with REW or Geddes room mode sim.
Originally Posted by tuxedocivic /t/1518671/seos-12-waveguide-builds...r-high-mounted-in-wall-speakers#post_24379918
Have a look here: http://www.diysoundgroup.com/forum/index.php?topic=127.0
I had a guy over on Sunday to here a variant of these. Username Tyee. PM him if you'd like, although he didn't hear exactly that speaker but a variant. I just can't help but fiddle. The one he heard needs some changes. The one in that thread is better. I now use the DNA-360 for the one in that thread. And it has a very tall vertical lobe.
Originally Posted by noah katz /t/1518671/seos-12-waveguide-builds...r-high-mounted-in-wall-speakers#post_24381939
Good point on the highs.
Another option you can do since you have the depth is to tilt the whole box down, and/or put the WG below the woofer.
Originally Posted by CZ Eddie /t/1518671/seos-12-waveguide-builds...h-mounted-in-wall-speakers/0_50#post_24382060
And if the Waveguide were on the bottom, it may not cause too many diffraction issues for the left & right side lips.
Originally Posted by noah katz /t/1518671/seos-12-waveguide-builds...r-high-mounted-in-wall-speakers#post_24382717
? Tilting the box to point down means the the bottom of the box is further into the wall
