Status
Not open for further replies.
1 - 4 of 4 Posts
I just received a Panasonic rv-32 and find that its remote and the remote for my e-20 both control the two machines. Is there an alternate set of remote codes, especially for on/off for either one? Otherwise, I'll have to turn one machine off manually if I want to use the other one.
TIA,
Rick
Check your E20 manual. You can change the E20 to use a secondary remote code protocol. Perfect for setups with two Panasonic decks.
Discussion Starter · #3 ·
Thanks Mike,
I'll check it out later.
I just bought a new E20 today to replace the one that got fried by lightning on March 31. I just noticed that you can set the the E20 to use one of three different sets of remote codes. So you could have three of these decks with no worries. It's a setting in the "Action" menu, I think. Then press power-1, power-2, or power-3 on the remote to make the remote match what you set the player to use.
Enjoy.
1 - 4 of 4 Posts
Status
