I will paste the text of my e-mail msg to Spectre Tech Support below. I just got this unit today and am a little perplexed about displaying 16:9 Widescreen inputs, especially when I have that kind of input and when you depress the "aspect" button on its remote, it gives you 4:3 options... Any way, if one of you kind folks can help me solve this small item, I won't need to take it back. Now to paste the e-mail:.............
Dear Tech Support: Just received the above HDTV this afternoon and am in the process of checking it out. There are many features that I think are well thought out; however, I seem to be having difficulty in the 16:9 Aspect Ratio auto selection feature
Currently I have a DirecTV SD D-10 Receiver connected to this unit via S-Video/Composite cables. The D-10 Receiver is set to 16:9 Widescreen. The several channels I selected, then using the ASPECT button on the controller only gave me the three Source 4:3 Wide Normal and Zoom options. (even though some were letterboxed
I was caught off guard while using the X32's set up menu as it didn't allow me to select the 4:3 or the 16:9 Aspect Ratio. Then on Page 89 of the X32's Manual, it stated, The TV will display the TV's channels signal format automatically. It further stated that if you are watching a widescreen movie in 1:85:1 or 2.35:1 ratio, you will still get black bars on the top and bottom of the screen. So I tested this out.
I connected my JVC DR M-10 DVD Video Recorder using component video and composite audio cables. I got out my DVD of Disney's Monsters, Inc. and selected its Widescreen Version 1.85:1 Enhanced for 16X9 Televisions
--When I punched info on the remote for this 1.85:1 DVD, it displayed YPbPr1 720X480P.
--I didn't get Black Bars on the top or bottom.
--I didn't get any 16:9 options when I depressed the Aspect button on the controlleronly the three source 4:3 Wide Normal and Zoom.
The Burning Question:
Should the TV display the 16:9 Aspect Ratio when I have a 16:9 Source (such as the WS 1.85:1 DVD I used above)?
Should the Remote's Info button display SD for a 720X480P DVD Input signalit did! I thought 720 might be High Def?
So, did I miss something that is causing me not to get 16:9 or HD to display when I actually have that kind of input? Sure hope you can guide me here.
Thanking you in advance
