Status
Not open for further replies.
1 - 2 of 2 Posts
Hello,
I'm getting everything installed today. My HD-100 will be sitting inside of an entertainment center. There isn't much ventilation in there. There is a glass door on the front, and the back has a screw-in panel with openings at top and bottom for cable runs. Will this be a problem? I know it has a built in cooling fan - will this be enough? Do other STB's heat up as well? Will this be a problem regardless of which box I get? I currently have a Sony SAT-A55 and it gets warm, but I have had no problems with it.
THANKS!
Marc
You should be fine mweppner.
Juan
1 - 2 of 2 Posts
Status
