1 - 4 of 4 Posts
· Registered
I have been reading A LOT in this section. I am still a novice with regards to home theater audio. One question I have is what should I do with my crossover settings for my setup. Here are the speakers and sub:
BIC America Venturi V1220 Subwoofer
Athena C1, 2 F1's, and 2 Point 5's in the rear
My room is 14x24. I watch HDTV, HD DVD/Blu-ray/DVD, and play Wii. My current receiver (Harman Kardon AVR-247) can set the crossover for each speaker. I run PCM over HDMI for the Hi-def players and bitstream DD from the satellite.
And my sub has a crossover setting as well. Any help would be appreciated. Thanks
· Registered
1. You set the AVR's crossover about 10Hz above each speaker's rated -3dB low end point.
2. You turn OFF the sub's crossover or, if you cannot, turn it to the highest frequency it has.
· Registered
Discussion Starter · #4 ·
I'll try those suggestions. Thanks!!!
1 - 4 of 4 Posts
